Fuel leak help-- crossposted
Old May 12, 2015 | 06:56 PM
ItsAChummins's Avatar
Default Fuel leak help-- crossposted
Okay I've got a 94 chevy 3/4 ton with a 12v swapped into it. Fresh reseal on ve pump I finished last week. I also turned up the pressure a bit and swapped in a new fuel pin at the same time, along with a 366 governor spring. My problem now is this:
I've got a massive leak coming from the manual fuel shut off valve and cannot get it to reseal with just the provided oring. When I disassembled it all there was only an oring, I'm wondering if there is supposed to be a washer or other type of gasket that holds that oring in, as it does not seem to be staying in place any longer.
Attached Thumbnails Fuel leak help-- crossposted-11263724_10207051630713299_236037385_n.jpg
Old May 13, 2015 | 04:06 AM
Jet A Fuel's Avatar
Looks to me like a metal cup style/rubber lip seal fits in there and seals to the shaft.
Anyone had one of these P pumps apart?
bump
Old May 14, 2015 | 12:27 PM
thats what i was thinking but none of the parts diagrams show this apart.
Old May 14, 2015 | 07:39 PM
92betsy's Avatar
Sorry I don't have an answer, but did a google search for ve shutoff leak and it came up with some info that might help. to tired to seperate the results though, sorry.
https://www.google.com/search?q=manu...st+gen&spell=1
Old May 15, 2015 | 06:06 AM
blackduck's Avatar
How did you turn up the pressure? and how high is it?
Old May 15, 2015 | 05:01 PM
Thanks guys fixed the leak using a larger oring and a crush washer.
External electric fuel pump. not much higher then stock, just enough to maintain good pressure after the swap.
Dale9411
Dec 4, 2022 06:51 PM
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
Dec 5, 2014 08:30 AM
