94 Chevy 12v Cummins-- Resealed ve pump new leak parts question
Old May 12, 2015 | 04:19 PM
ItsAChummins's Avatar
Default 94 Chevy 12v Cummins-- Resealed ve pump new leak parts question
Okay I've got a 94 chevy 3/4 ton with a 12v swapped into it. Fresh reseal on ve pump I finished last week. I also turned up the pressure a bit and swapped in a new fuel pin at the same time, along with a 366 governor spring. My problem now is this:
I've got a massive leak coming from the manual fuel shut off valve and cannot get it to reseal with just the provided oring. When I disassembled it all there was only an oring, I'm wondering if there is supposed to be a washer or other type of gasket that holds that oring in, as it does not seem to be staying in place any longer.
Attached Thumbnails 94 Chevy 12v Cummins-- Resealed ve pump new leak parts question-11263724_10207051630713299_236037385_n.jpg
Old May 14, 2015 | 12:26 PM
bump
Old May 15, 2015 | 05:02 PM
Fixed the leak with a larger oring and a better washer from a pool water pump.
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
Tory4
For Sale
Feb 1, 2015 08:33 PM
mtedrick4
Diesel Engine Conversions
Oct 13, 2014 09:25 PM
