96 12 valve oil coming out of exhaust manifold
Old May 2, 2015 | 08:05 PM
Jake12valve's Avatar
Default 96 12 valve oil coming out of exhaust manifold
Hey I've been stressing bad over this so I hope yall can help.
I have a 96 12 valve cummins.
I just did a head gasket due to little water leak under t-stat housing. Well I had the machine shop work the head replace seals on valves the rocker pedestals, valve springs and valves, and push rods are original. There are no hop ups nor hot rod stuff done to it. I torqued all bolts and adjusted my valves like the chilton manual said. So on first crank up after doing all of this, I tried to crank it I primed it and I gave it a shot of ether, BAD IDEA I KNOW!!!, well it cranked it smoked horribly and idled ruff well I i drove it maybe quarter of a mile noticed it wasn't better, so I pulled back in and noticed oil coming out of down pipe on turbo, "I hadn't hooked exhaust back up to turbo yet" so of course a bad turbo!!! Well I replaced it and it's still doing it. So I pull my turbo and manifold off and look into the head, if your looking at the side of the block on passenger side where the exhaust manifold bolts up, well if you start at the firewall and count from there at the exhaust port closest to the firewall and go from 1 to 6 and 6 being the front of the motor the two exhaust ports close to rhe firewall are dry and the rest are wet with oil. No fuel just oil and I'm 99.9% sure it's not coming from the turbo. So if you could please help I would really appreciate it. Also keep in mind never ever had this issue before.
Thanks
Old May 3, 2015 | 09:35 PM
97cummins's Avatar
How did the valve seats look when they had the head pulled off?
oil could be leaking past the valve seats.
Old May 3, 2015 | 10:31 PM
They replaced them
Old May 3, 2015 | 10:33 PM
It's got a strong odor when I crank it like ether maybe it's not diesel smelling or you know the normal smell
Old May 10, 2015 | 11:09 PM
97cummins's Avatar
does it still have the running issue with the oil issue?
as for the smell,
Old May 10, 2015 | 11:57 PM
Yes it does
avatardvr
18
Aug 8, 2019 12:38 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
lacrab
Sep 10, 2015 01:17 AM
Jet A Fuel
Aug 3, 2015 10:45 AM
pro graphic solutions
Feb 10, 2015 03:48 PM
