Amsoil oil bypass kit
Old Apr 27, 2015 | 01:48 AM
Spk329's Avatar
Default Amsoil oil bypass kit
Anybody use this product on the 6.7 cummins
Best,
Steve
Old May 23, 2015 | 12:46 PM
El Pozzinator's Avatar
yes. i'm currently at 5300 miles on this oil change and analysis is still saying the oil is good. i'm bone stock, so i swap the filter every 3-5k and change the oil every 10k whether it needs it or not.
could only get 2 of the 3 mounting bolts in securely, though. that back one is a pain in the rear, as it's partially under the intake.
also, if you plan on adding a GDP mk2+ 2um fuel filter after your factory filter, things get complicated because they both mount in the same place. a dual pump would mount there as well. so there's that to consider. it can be mounted elsewhere with some creativity and line swapping.
one complication i've had is oil leaking from the return line in the supplied replacement filler cap. solved that by removing the fitting and re-wrapping it with thread sealer and cranking it in there all the way. there's also a bit of a clearance issue with the hood liner, but some quick work with a razor knife fixed that, and it's not enough to contact hard parts even if you don't trim the liner.
wlofton
11
Jun 26, 2018 08:58 AM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
helton87
For Sale
Jun 3, 2015 02:36 PM
coors_man_2005
Dec 15, 2014 10:23 AM
