TROUBLE CODE P1755 ?
Old Apr 13, 2015 | 12:25 PM
robbyS's Avatar
Default TROUBLE CODE P1755 ?
Can anyone give a straight answer on what this code is ? This morning my truck wouldn't start temperature was in the mid 30's and I did cycle the heater once but did not start. Drive my other vehicle to work and tried again later and truck started like normal but the check engine light came on so I checked the code and got the 1755 code. My truck had a catastrophic engine failure a couple months ago so I now have a brand new engine from cummins and all new injectors with only 1200 miles on it. I'm not ready for more problems yet ! Any input welcomed and appreciated
Old Apr 14, 2015 | 08:04 PM
dangerous1965's Avatar
No Such code number to be found? Maybe a tranny code?
Third Gen DTC List.
Got a code? Check it here before you post.
3rd Gen 5.9 DTC List.
Yes, we have a similar list posted in the Tech Area as too.
Now you don't have to go fishing for it.
Sniped from multiple sources:
P0016 Crankshaft/Camshaft Timing Misalignment/Out-of-Sync
P0071 Ambient Temperature Sensor Performance / Rationality
P0072 Ambient Temperature Sensor Low
P0073 Ambient Temperature Sensor High
P0088 Fuel Rail Pressure Too High
P0106 Manifold Absolute Pressure Sensor Performance / Rationality
P0107 Manifold Absolute Pressure Sensor Low
P0108 Manifold Absolute Pressure Sensor High
P0111 Intake Air / Charge Temperature Sensor Performance / Rationality
P0112 Intake Air / Charge Temperature Sensor Low
P0113 Intake Air / Charge Temperature Sensor High
P0116 Engine Coolant Temperature Sensor Performance / Rationality
P0117 Engine Coolant Temperature Sensor Low
P0118 Engine Coolant Temperature Sensor High
P0128 Cooling System Error / Thermostat Rationality
P0148 Fuel Delivery Error
P0169 Water-in-Fuel Detected For Too Long
P0192 Fuel Rail Pressure Sensor Low
P0193 Fuel Rail Pressure Sensor High
P0201 Fuel Injector 1 Circuit
P0202 Fuel Injector 2 Circuit
P0203 Fuel Injector 3 Circuit
P0204 Fuel Injector 4 Circuit
P0205 Fuel Injector 5 Circuit
P0206 Fuel Injector 6 Circuit
P0217 Coolant Temperature Too High
P0219 Engine Overspeed
P0234 Turbocharger Overboost Condition
P0236 Turbocharger Boost Pressure Sensor Performance / Rationality
P0237 Turbocharger Boost Pressure Sensor Low
P0238 Turbocharger Boost Pressure Sensor High
P0251 Injection Pump Fuel Valve Feedback
P0300 Multiple Cylinder Misfire
P0301 Cylinder 1 Misfire
P0302 Cylinder 2 Misfire
P0303 Cylinder 3 Misfire
P0304 Cylinder 4 Misfire
P0305 Cylinder 5 Misfire
P0306 Cylinder 6 Misfire
P0335 Crankshaft Position Sensor Circuit
P0336 Crankshaft Position Sensor Performance
P0337 Crankshaft Position Sensor Circuit Low
P0338 Crankshaft Position Sensor Circuit High
P0340 Camshaft Position Sensor Circuit
P0341 Camshaft Position Sensor Performance / Rationality
P0381 Wait-to-Start Lamp Inoperative
P0461 Fuel Level Sensor 1 Performance / Rationality
P0462 Fuel Level Sensor 1 Low
P0463 Fuel Level Sensor 1 High
P0477 Exhaust Pressure Control Relay Low
P0478 Exhaust Pressure Control Relay High
P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay)
P0483 Cooling Fan Speed
P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1
P0514 Battery Temperature Sensor Performance / Rationality
P0516 Battery Temperature Sensor Low
P0517 Battery Temperature Sensor High
P0521 Oil Pressure Sensor Performance / Rationality
P0524 Oil Pressure Too Low
P0532 A/C Pressure Sensor Low
P0533 A/C Pressure Sensor High
P0541 Intake Air Heater Relay 1 Low
P0542 Intake Air Heater Relay 1 High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0572 Brake Switch 1 Low
P0573 Brake Switch 1 High
P0580 Speed Control Multiplexed Switch 1 Low
P0581 Speed Control Multiplexed Switch 1 High
P0602 Control Module Programming Error/NotProgrammed
P0604 Internal Control Module RAM Integrity Failure
P0606 Internal ECM Processor
P0607 ECU Internal Performance
P0622 Generator Field Control Circuit
P0628 Fuel Pump Relay Circuit Low, or Fuel Lift Pump Control Circuit Low
P0629 Fuel Pump Relay Circuit High, or Fuel Lift Pump Control Circuit High
P0630 VIN Not Programmed in PCM
P0633 SKIM Key Not Programmed in PCM
P0642 Sensor Reference Voltage 1 Circuit Low
P0643 Sensor Reference Voltage 1 Circuit High
P0646 A/C Clutch Relay Circuit Low
P0647 A/C Clutch Relay Circuit High
P0652 Sensor Reference Voltage 2 Circuit Low
P0653 Sensor Reference Voltage 2 Circuit High
P0698 Sensor Reference Voltage 3 Circuit Low
P0699 Sensor Reference Voltage 3 Circuit High
P0700 Transmission Control System (MIL Request)
P0837 Four Wheel Drive (4WD) Switch Performance / Rationality
P0838 Four Wheel Drive (4WD) Switch Circuit Low
P0839 Four Wheel Drive (4WD) Switch Circuit High
P1652 J1850 Communication Bus
P2121 Pedal Position Sensor 1 Performance / Rationality
P2122 Pedal Position Sensor 1 Low
P2123 Pedal Position Sensor 1 High
P2127 Pedal Validation Switch 2 Low
P2128 Pedal Validation Switch 2 High
P2146 Fuel Injector Group 1 Supply Voltage Circuit
P2149 Fuel Injector Group 2 Supply Voltage Circuit
P2266 Water in Fuel Sensor Circuit Low
P2269 Water in Fuel Condition
P2502 Charging System Output Voltage
P2503 Charging System Output Low
P2504 Charging System Output High
P2509 ECM/PCM Power Input Signal Intermittent
P2607 Intake Air Heater Relay 2 Low
P2608 Intake Air Heater Relay 2 High
P2609 Intake Air Heater System Performance
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103Mass or Volume Air Flow Circuit High Input
P0104Mass or Volume Air Flow Circuit Intermittent
P0105Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0109Intake Air Temperature Circuit Malfunction
P0110IAT Circuit Malfunction
P0111Intake Air Temperature Circuit Range/Performance Problem
P0112Intake Air Temperature Circuit Low Input
P0113Intake Air Temperature Circuit High Input
P0114Intake Air Temperature Circuit Intermittent
P0115Engine Coolant Temperature Circuit Malfunction
P0116Engine Coolant Temperature Circuit Range/Performance Problem
P0117Engine Coolant Temperature Circuit Low Input
P0118Engine Coolant Temperature Circuit High Input
P0119Engine Coolant Temperature Circuit Intermittent
P0120Throttle Position Sensor/Switch A Circuit Malfunction
P0121Throttle Position Sensor/Switch A Circuit Range/Performance Problem
P0122Throttle Position Sensor/Switch A Circuit Low Input
P0123Throttle Position Sensor/Switch A Circuit High Input
P0124Throttle Position Sensor/Switch A Circuit Intermittent
P0125Insufficient Coolant Temperature for Closed Loop Fuel Control; ECT Excessive Time to Closed Loop Fuel Control
P0126Insufficient Coolant Temperature for Stable Operation
P0128Coolant Thermostat Malfunction
P0130O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170Fuel Trim Malfunction (Bank 1)
P0171Fuel Trim System Lean (Bank 1)
P0172Fuel Trim too Rich (Bank 1)
P0173Fuel Trim Malfunction (Bank 2)
P0174Fuel Trim too Lean (Bank 2)
Old Apr 16, 2015 | 11:38 AM
robbyS's Avatar
@dangerous1965.
Thanks for that list. I went ahead and put in new and better quality batteries and cables, cleaned all my grounds and cleared the code run like it should and no codes. Starting to move this wknd and will be putting some good miles on it with a trailer so time will tell. Thank you again for your help
Old Apr 16, 2015 | 02:22 PM
Bigg Redd's Avatar
Hey Dangerous1965, thanks for posting the trouble codes dude. Great post!!
dwmeehan
Sep 6, 2015 04:20 PM
flash7210
Jul 5, 2015 09:25 AM
Bighouse
Apr 9, 2015 06:51 PM
dmax0202
Feb 18, 2015 04:12 PM
Backhoeman
Jan 3, 2015 12:53 PM
