Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Kubota on WVO
Old Apr 6, 2015 | 10:54 AM
DetroitDiesel's Avatar
Default Kubota on WVO
Hey, I was wondering if any one has ran a kubota on WVO, specifically the v2203di? I have one swapped into my ranger now with a K03 turbo on it and I'd like to try running it on WVO this summer. Anyone with experience or advice let me know! Thanks
Old Apr 21, 2015 | 12:57 PM
yellow68gto's Avatar
I have been thinking the same thing but WMO. My current motor is a IDI. I haven't finished the swap but already building my WMO setup, Including Centrifuge
I have not found anyone that has run them on alternative fuels. I would assume they should run good.
I am planning a 2 tank system running my main 10 gallon tank on D2 for start and stop and a second 30 gallon in bed tank with WMO. I will be heating with coolant(hopefully 180*) I commute only 50 miles daily but if it works out I will be driving it everywhere.
I have an unlimited supply of descent waste oil and used hydraulic fluid. I will be cutting with Gas at 10%.
I am hoping to run the wmo straight and not have to mix with D2. My area rarely sees freezing. Lows are generally mid 30's in winter and mid 70's summer at night.
Good luck and hope these little motors surprise us again!!!!
Old Apr 27, 2015 | 07:06 AM
You should have no problem with that running an idi. All the mennonites around my around do that with waste oil. Will be interesting to see whether you need a fuel heater or not
Old Apr 27, 2015 | 08:06 AM
I don't know if I will need it but I am planning on one to hear my fuel filter
Old Nov 4, 2015 | 07:27 AM
ALWAYSREADYROB's Avatar
I reccomend a vegtherm in line fuel heater
yellow68gto
Wanted To Buy (WTB) - Used
Oct 13, 2016 10:59 AM
flyinmonkeys32
Diesel Engine Conversions
69
Apr 30, 2015 12:09 AM
yellow68gto
Apr 10, 2015 12:02 PM
Pitdawg
Feb 28, 2015 05:03 PM
DetroitDiesel
86
Jan 25, 2015 02:45 PM
