pulling to the right constantly
Old Mar 28, 2015 | 09:09 PM
rack1234's Avatar
Default pulling to the right constantly
Hey guys, was wondering if any of you ever had any issue with your truck pulling to the right constantly? It started right at 80,000 miles. I have replaced all ball joints, hub bearings, wheel joints, rotors, calipers and pads. I have had it aligned at 3 different places and they all say the same thing, " Nothing is worn out and everything is tight". Well, something is obviously out, and I cannot believe that an axle tube could bend on asphalt roads. Has anybody ever had any issue like this? The only thing I have not started to replace text are the steering components such as tie rod, tie rod ends, track bar etc.etc.. Sorta at a loss andit is chewing up my 35 inch toyos on the right side! Any suggestions would be greatly appreciated!!!
Old Mar 28, 2015 | 09:56 PM
Regcabguy's Avatar
My Toyo MT's exhibited the typical right radial pull. My 2.0 Fox steering stabilizer pressurized to 150 psi corrected it. I now have Toyo AT2's with neutral handling and had to go back to the stocker as deflating the 2.0 to anything less than 70# renders them useless.
Brclouse
Nov 18, 2015 08:44 AM
oneloud59
May 16, 2015 10:00 AM
Mikeyfz45083
Transfer Sled Pulling
Nov 14, 2014 11:04 AM
