crank no start i'm lost
Old Mar 4, 2015 | 10:44 AM
mrgofast13's Avatar
Default crank no start i'm lost
I have a 1997 f350 4x4 7.3 auto trans. cranks nice and strong but wont fire checked all the fuses no issues there. when I turn the key on however the CEL comes on for about 1/2 second then turns off. don't know if maybe its a computer issue or not. not sure of the history of the truck either. can anyone point me in the right direction?
Old Mar 4, 2015 | 12:21 PM
mrgofast13's Avatar
just gave it a snort of silicone spray fired right up and ran for 20 minutes shut down and now wont restart without a snort.
Old Mar 4, 2015 | 08:29 PM
joebob3093's Avatar
Moderator
First thing you need to do is scan it to see if there are any codes
Old Mar 5, 2015 | 04:46 PM
excutioner's Avatar
if it ran for 20 minutes it's either the injector pump or fuel pump.do you know what your fuel pressure is under a load.
Old Mar 5, 2015 | 08:49 PM
joebob3093's Avatar
Moderator
There is no injection pump..... And they will run with no fuel pump
Old Mar 5, 2015 | 10:00 PM
excutioner's Avatar
that's what i was getting at on the fuel pump.the motor does have an injector pump
unless there are aliens carrying the fuel to the cylinder .
Old Mar 6, 2015 | 03:29 AM
excutioner's Avatar
we are talking about the old style 7.3 right.the injector pump sets in the valley
and the pump is a burr to get to.i know if the fuel pump quits they will use what ever fuel they have in the lines and then die.but you are sayinging they will literally run with out the pump im confused here.what about the ipr thst regulates the hpo or do these motors not have these.i know the 99s do but i just seen this was 97.
Old Mar 6, 2015 | 09:24 AM
joebob3093's Avatar
Moderator
If you do not know do not respond. There is no injection pump, they have a high pressure oil pump. And if the fuel pump quits they will still run but not very well.
Old Apr 28, 2015 | 06:47 PM
phlorit's Avatar
First I agree with joebob3039. Is there any codes? Next, wouldn't it be a good idea to see if the fuel bowl has fuel in it? If it is dry, then fuel delivery to the bowl has stopped somewhere I believe. Assuming this is yes, is there anything coming out of the exhaust at all? White smoke, fuel smell, etc.?
Fuel is delivered to the pump and then pushed into the fuel bowl. It is then sent through the HPOP to the two rails that run into your head covers and feeds the injectors with high pressure diesel. If this is all going well, then the fuel injectors are not triggering / opening and or the fuel is to cold to fire (hence the need for glow plugs).
If fuel is getting to the cylinder and not firing, you will know it. Usually lots of white smoke.
Old Apr 28, 2015 | 08:34 PM
phlorit's Avatar
Fixed my dumb *** prior statements about fuel delivery.
Fuel is delivered to the bowl and then pushed into the fuel pump. It is then sent through to the two rails that run into your head covers and feeds the injectors with high pressure diesel coupled by HPOP oil that forces the injection to occur at the injectors. If this is all going well, then the fuel injectors are not triggering / opening and or the fuel is to cold to fire (hence the need for glow plugs).
SkiDooGuy
Sep 9, 2015 05:55 PM
ish1521
Aug 26, 2015 08:42 PM
tmcc14
Apr 21, 2015 03:59 PM
ebg2g
Mar 29, 2015 06:15 PM
musikagod
11
Nov 30, 2014 07:22 AM
