2006 cummins injectors
Old Feb 26, 2015 | 06:19 PM
Zachbishop's Avatar
Default 2006 cummins injectors
Finally broke down and took the truck in to have it tested after terrible gas Milage turns out all 6 injectors are bad and was quoted 3000 out the door for new Bosch injectors and labor, is this fair? And are these the injectors I should put in ?
Old Feb 26, 2015 | 07:47 PM
dangerous1965's Avatar
Yeah sounds about right you can get two other quotes! The injectors are 2400 +
Be sure they get NEW ones not rebuilt! Also install a 2 micron filter BEFORE the CP3!
Old Feb 26, 2015 | 11:21 PM
Zachbishop's Avatar
Would that not be hard on my cp3 causing it to work harder?
Old Mar 1, 2015 | 11:01 AM
akhappyjack's Avatar
whats wrong with remans as long as their done by a reputable rebuilder ? I run a diablo programmer with 100gp air dog and have had no problems with injectors. but I run a quart of dextron through the tank once in a while.am i just lucky?
Old Mar 4, 2015 | 08:15 PM
Regcabguy's Avatar
Up Glacier diesel
Good price! New ones are the way to go.
Here's a link for the Glacier 2 micron fuel filter setup.
Mine's been on for 16K. Guys have measured fuel pressure and no issue with this additional filtration setup.
Glacier Diesel Power | Diesel Performance Truck Parts | Dodge Cummins Ford Duramax | - Product Detail
Old Mar 5, 2015 | 02:05 AM
el segundo's Avatar
How many miles did you have before the injectors went out?
Old Mar 5, 2015 | 09:48 AM
The filter is before the CP3 pump pressure is the same to the CP3 except you have cleaner fuel which leads to a lot longer injector life!
Old Mar 5, 2015 | 09:50 AM
Stop using dextron BAD for injectors! Use 2 stroke oil one ounce per gallon for optimum lube!
nathanmueller
Diesel Engine Conversions
Sep 8, 2015 03:30 PM
Arog223
Aug 16, 2015 07:15 PM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
Sbboozer
Nov 16, 2014 05:52 PM
