06 Cummings won't turn over, no gauges on cluster
Old Feb 19, 2015 | 03:11 PM
Brad Boucher's Avatar
Default 06 Cummings won't turn over, no gauges on cluster
06 dodge 3500
Cleaned battery terminals and tried to drive the next day nothing when you turn key. Cluster appears dead, no interior lights, no door locks. I can hear fuel pump when key is turned to start. Headlights work power windows and mirrors work. Edge cts shows 12.2 volts. Batteries are good fuses in tipm are good. Grounds look good as well as terminals. Any info is greatly appreciated. Thanks Brad B
Old Feb 23, 2015 | 07:07 PM
j johnson's Avatar
try undoing the edge..turn back to stock then disable it..if it starts then thats ur problem...scott
Old Feb 23, 2015 | 07:50 PM
Thanks but edge I'm using is just a monitor not a programmer.
Old Feb 24, 2015 | 06:49 PM
j johnson's Avatar
my thinking its got to be a fuse of some kind..thats the only thing poping up in my head...scott
Old Feb 24, 2015 | 08:07 PM
I checked all the fuses. I'm thinking it's in the tipm fuse box. Came home yesterday and everything was normal. I drove it to repair shop and will see what they come up with. Thanks again Brad
flainn
Oct 12, 2024 09:39 AM
klein444
Jun 20, 2015 11:48 PM
May 1, 2015 08:10 AM
carid
Diesel Bombers Sponsors
Dec 9, 2014 03:58 AM
Ibanimal
Oct 31, 2014 09:07 AM
