Marine 370 pros and cons
Old Feb 17, 2015 | 01:05 PM
torque monsters diesel's Avatar
Default Marine 370 pros and cons
OK so I will be running marine pistons marine 370 injectors an hx35 turbo a bd fuel pin and 3200 rpm spring added timing a banks power elbow and four inch exhaust in a first gen Cummins..... does anyone see a problem in this recipe?
Old Feb 28, 2015 | 04:15 PM
dan123dbl's Avatar
Your truck is intercooled so it needs 145* injectors. 370s are 155* and meant for the non intercooled pistons.
Old Feb 28, 2015 | 04:17 PM
Yes I know that is why I am using marine pistons
Old Mar 1, 2015 | 07:35 AM
dan123dbl's Avatar
Oh sorry I didn't read that part.
I think an hx35 would run quite hot with that setup. 370s are a 5 x 12 from what I just read. Have you thought about any other turbo options?
Old Mar 1, 2015 | 09:07 AM
62 millimeter compressor wheel for the hx35? I've seen Em
Old Mar 1, 2015 | 05:20 PM
dan123dbl's Avatar
You'll still be flowing it through the 3" exhaust outlet. It all depends on your budget and purpose of the truck. I'd recommend an he351cw if you tow at all. You can always go compounds too.
