Code PO540
Old Feb 16, 2015 | 08:06 AM
dmax0202's Avatar
Default Code PO540
Throwing code PO540 at me got advise to change intake air heater still throwing the same code do not want to keep replacing parts that do not need replaced the truck seems to smoke more than usual at idle any help would be appreciated
JP
Old Feb 16, 2015 | 09:51 AM
j johnson's Avatar
check and see if u have power there ...if not then check the fuse...scott
Old Feb 16, 2015 | 01:52 PM
dmax0202's Avatar
no power fuse is good
Old Feb 16, 2015 | 08:41 PM
gunman41mag's Avatar
Moderator
intake heater code P0540.check your relay.
Old Feb 18, 2015 | 04:12 PM
dmax0202's Avatar
Default PO540 code
from what I can tell it is the relay that they want $262 for whew are they proud of that little goodie.... turns out I can get the whole controller for $100 and change went that route, that should do it.... it better do it!!
thanks for your help!
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
UC Kid
Nov 7, 2014 10:56 PM
