01 cummins cranks but wont start
Old Feb 2, 2015 | 08:53 PM
Rusher48's Avatar
Default 01 cummins cranks but wont start
I was driving down the road and my Cummins just died on me. everything I read said it was the injection pump, so I changed that but still wont start. I checked all my grounds got new batteries, and good fuel pressure. I bleed all the air out of the lines, and even tried spraying ether but still nothing happened.I have some codes that said cam shaft sensor and crank sensor and my throttle position sensor. could those cause it to not start or is something else? open for any ideas to get her running again.
Old Feb 3, 2015 | 10:21 AM
rschriek's Avatar
Are you getting power and ground at the injection pump does your tach work cam sensor sends signal to tach. my 01 only has a cam sensor no crank sensor.
Old Feb 7, 2015 | 04:18 PM
Rusher48's Avatar
What is the tach? I just put a new cam sensor in today and it still didn't do anything?
Old Feb 7, 2015 | 08:25 PM
24vmaniac's Avatar
Crank sensor is bad if your tachometer isn't registering. 👍
Old Feb 9, 2015 | 11:28 AM
rschriek's Avatar
tach is the rpm gauge on the left of the speedo. If you have rebuilt injection pump a working fuel pump that comes on has pressure and fuel supply you probably have a wiring issue on your injection pump. this is a link for a no start read it VP44 Diagnostic here is a link for a wiring diagram Mopar1973Man's Dodge Cummins Articles - Dodge Ram Turbo Cummins 24 Valve Engine Wiring
Old Feb 9, 2015 | 11:29 AM
rschriek's Avatar
Old Feb 18, 2015 | 08:56 PM
Rusher48's Avatar
I was finally able to narrow it down to my airdog lift pump is there anyway to get just the motor or do I have to get a whole new assembly?
Old Feb 20, 2015 | 05:19 PM
AHolt's Avatar
If you bought pump new, call them they will replace it.
Rusher48
Jul 2, 2020 08:39 AM
mcclusk
Feb 21, 2015 09:50 PM
rschriek
Jan 26, 2015 07:30 AM
gator515
Jan 14, 2015 01:56 PM
Downd19
Dec 30, 2014 02:49 PM
