New LB7 owner, suggested mods?
Old Feb 1, 2015 | 07:09 PM
lb7Garrett's Avatar
Default New LB7 owner, suggested mods?
I have just purchased a 2003 Duramax. It has 130,000 miles and has been very well maintained. It has NEVER had the injectors done and it still runs like a champ. This is my daily driver and I am not interested in insane power. I will be towing very seldom. I am looking for mods that will spunk up my truck a bit and also tips on keeping it in good running order. For example the cat fuel filter? Thank you in advance for your responses
Old Feb 1, 2015 | 11:18 PM
97cummins's Avatar
You can get a better drop in air filter that's cleanable, that will save money in the long run. Diesels love to breath better. Then you can change the exhaust to a better flowing system.
And a mild tuner and that would be a good start.
Old Feb 5, 2015 | 12:53 PM
lb7Garrett's Avatar
Okay thank you for the reply, what do you mean by a drop in air filter? A k&n? Or a new intake?
Old Feb 6, 2015 | 01:19 AM
detroitdiesel idi's Avatar
no no no on the k&n get a s&b or any other intake other than k&n unless you wanna dust the engine. A cat fuel filter upgrade is a must on these trucks and the common rail cummins the factory only installs 7 micron fuel filters and these newer injection systems require at least a 2 micron. biggest reason for duramax and cummins common rail injector failure.
Old Feb 8, 2015 | 05:18 PM
redneck1057's Avatar
Get a lift pump!!! all of them are pretty good i guess, I would get an Airdog, Kennedy, or a FASS. This will prolong the life of your injectors. However i would start saving for the injectors because they could really go out at any time. If i were you i would do lift pump and then either wait till they go out or just bite the bullet and replace them.
Old Feb 12, 2015 | 08:55 AM
Sokr915's Avatar
I agree with a lift pump. Help those injectors as much as you can. I have a FASS 150 and love it. After that I would go to a dp back exhaust, S&B intake, boost increase valve, efi live
Old Feb 15, 2015 | 09:02 PM
2004LB7's Avatar
Skip any aftermarket air filter as the stock one flows plenty. Meny test have shown this. I wouldn't go messing around with lift pumps or fuel filters. If you're injectors have been serving you good so far best not to upset them with fuel system changes. Keep using the fuel filter you currently buy and fill up at your same station. Lift pumps are good if you are draining your fuel rail or have a week cp3
If you just want a small bump in power then get efi live. A 40 to 50ish hp tune will make towing more fun and will usually not reduce the life of the transmission much. For mild bumps in HP you dont need any exhaust upgrades but that is up to you. Some report small increases in mpg from free flowing exhausts.
At this point, unless you want to go big, keep ot simple
Jason
2004LB7
29
Feb 29, 2016 06:00 PM
duramaxtuner
LB7 Performance
9
Aug 5, 2015 11:36 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
dieselpowa
Jan 26, 2015 03:02 PM
rtbcoop
Dec 30, 2014 02:13 AM
