Jim
Old Feb 1, 2015 | 06:16 PM
Jim Ringler's Avatar
Default Jim
Ihave a 1990 dodge 5.9 cummins. Stopped running a while back and now working on it again. First my injector pump had been leaking, so I figured in finally died. Replaced VE pump, filter and injectors. Still won't fire even with new battery. HELP
Old Feb 1, 2015 | 11:25 PM
97cummins's Avatar
After the pump, injector and filter replacement, there may be a lot of air in the fuel system. Are you getting any fuel out of the injector lines?
You may need to check the lift pump also.
Old Feb 2, 2015 | 08:26 AM
I did bleed all injector lines and they all spurted fuel as I went through them.
