Need help... P0088 /P0251
Old Jan 24, 2015 | 06:18 PM
pitbulls3489's Avatar
Default Need help... P0088 /P0251
I have a 2003 5.9 cummins and I've read the forums till my eyes are about to fall out, I'm stumped? My truck starts fine but has a loud high pressure sound and when I start driving it, it Boggs down at around 40mph.. I have replaced the Fca, changed out the fca connections ,tested the connections,changed the fuel pressure sensor, rail pressure valve, fuel filter? The only things I have done are change the cp3 or the cam positioning sensor.. Don't really think it's an injector cuz it doesn't smoke and starts great... ?? Can I get some suggestions?? Any1 had these codes...? Please help ...??
Old Jan 25, 2015 | 09:06 PM
Default Helloo
Can I get some help?
Old Jan 28, 2015 | 10:37 PM
South Texas Goat's Avatar
Possible Causes
FUEL CONTROL ACTUATOR (FCA)
FUEL PRESSURE SENSOR
INTERMITTENT CONDITION28 - DTC-Based Diagnostics/MODULE, Engine Control (ECM)/Diagnosis and Testing
P0088-FUEL RAIL PRESSURE SIGNAL IS ABOVE MAX LIMIT
P0251-CP3 PUMP REGULATOR CONTROLPossible Causes
FUEL PUMP
(K604) FUEL CONTROL ACTUATOR DRIVER OPEN
(K65) RETURN CIRCUIT OPEN FROM FCA TO ECM
(K604) FUEL CONTROL ACTUATOR DRIVER CIRCUIT SHORTED TO EXTERNAL VOLTAGE
(K65) FUEL CONTROL ACTUATOR RETURN CIRCUIT SHORTED TO EXTERNAL VOLTAGE
(K65) FCA RETURN CIRCUIT SHORTED TO (K604) FCA DRIVER CIRCUIT
(K604) FUEL CONTROL ACTUATOR DRIVER CIRCUIT SHORTED TO GROUND
(K604) FUEL CONTROL ACTUATOR DRIVER CIRCUIT SHORTED TO ANOTHER CIRCUIT
(K65) FUEL CONTROL ACTUATOR RETURN CIRCUIT SHORTED TO ANOTHER CIRCUIT
ECM
P088 and P0251 - Competition Diesel.Com - Bringing The BEST Together
Old Jan 29, 2015 | 08:41 AM
dangerous1965's Avatar
More than likely your PRV "Pressure relief valve" is worn out
pitbulls3489
Jan 27, 2015 05:06 PM
