Fuel leak can't find it
Old Jan 20, 2015 | 03:52 PM
4x4kingx889's Avatar
Default Fuel leak can't find it
I Have a 03 cummins which keep's leaking fuel near #5 injector line I replaced #4 and #5 line thinking it was one of them washed it off really good and it is still leaking fuel I can't see fuel leaking with engine running and even at a high rpm but fuel keep's coming up right where the rear engine lift point is by #5 any one have any tips?
Old Jan 21, 2015 | 09:07 PM
dangerous1965's Avatar
How long before it gets wet? Try a bright light at night. High pressure is hard to see probably only at full throttle when pressure is high Power brake it and see if you can spot it. Since you replaced the lines it may be the connector tube or fuel manifold
Old Jan 25, 2015 | 02:02 PM
I found it and fixed was #2 crossover tube
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
Dec 5, 2014 08:30 AM
