Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Delta Fuel Tank Install now have ????'s
Old May 11, 2008 | 06:40 PM
Luvnacummins's Avatar
Default Delta Fuel Tank Install now have ????'s
Well I got a fuel/tool box combo from member cbrahs aka high desert ravelco...and got it installed with some secret plumbing.... Here's a question for some of you fellas... I plan on tappping into the stock system so the delta tank will gravity feed into the stock tank.. How would some on you guys do it and do I have to worry about tank overflowing?? I know it won't come out of the cap because of the valve in that but anywhere else???
TIA
Shane
Old May 11, 2008 | 06:59 PM
Uncle Bubba's Avatar
Here's the simplest way I've found. They already went through the effort of puttin the kit together for you. Diesel Install Kit for Auxiliary Diesel Fuel Tank — Fits Ford and Dodge Trucks, Model# 011025 | Auxiliary Fuel Tanks | Northern Tool + Equipment
Old May 11, 2008 | 07:01 PM
Should get more exposure in here.
Old May 11, 2008 | 07:07 PM
Hell yeah brotha thanks!!
Just ordered it!!!
Old May 11, 2008 | 08:32 PM
Albin's Avatar
Don't forget to install a fuel water separator filter: http://www.rocketcityrockcrawlers.co...2007-06-18.pdf
Good luck.
Al
Old May 12, 2008 | 03:54 AM
Well it was a thought anyway. For the vent you could just use a rollover valve for a fuel pod. Cheap, easy to install and available at any race shop.
Here is for connecting the lines for the rollover shutoff protection. Fuel Tank Roll-Over Vent Valve
To connect back into your fuel filler neck just get one of the 2“ fuel Return Manifold's that they use for the FASS and Air Dog systems. I'm sure vendors sell them seperately. I just gave one away to Muddy a few weeks ago.
Old May 17, 2008 | 01:37 AM
So what did you end up doin here.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
