New truck some questions
Old Jan 9, 2015 | 10:02 PM
4x4kingx889's Avatar
Default New truck some questions
I just bought a 03 6 speed and have some questions I have a fuel leak somewhere around the fuel filter/fuel rail everything is wet and I was wondering where is a goodplace to look? now Ive worked on a few older 24v but never a common rail I know not to go sticking your hand in there looking for a leak as the high pressure can cause some harm..now Is it safe to work on it with the engine off or does it hold the pressure in even after it is not running? also do you bleed this like the older 24v ( crack injector line ) or is it a self bleeding system?
Old Jan 15, 2015 | 09:59 PM
South Texas Goat's Avatar
You checked the O-ring on the filter? Or the filter cap being loose? a little diesel makes a big mess.
Old Jan 16, 2015 | 06:01 AM
Yes there is a little fuel on the intake under line #5 filter canister is dry after I washed it I can't see any leaks with it running so it must be small but I ordered number #5 like and a #4 ( told its a good idea for spare )
Old Jul 29, 2015 | 09:14 PM
DieselDan_5.9's Avatar
correct me if i'm wrong but there should be somewhere where you can bleed the pressure from the fuel system. don't open any lines til you find that out, high pressure injection will drop you before you even realize what happened
Old Sep 10, 2015 | 03:45 AM
11B/11C's Avatar
the 4th fuel line is know to break or crack where it is held on by the bracket. i would check that line
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Dec 3, 2014 09:40 AM
Oct 14, 2014 08:40 AM
