Turbo/ injector advice
Old Jan 5, 2015 | 11:27 PM
Chris Pittman's Avatar
Default Turbo/ injector advice
Hey y'all need some advice , so I got a 1999 f250 fummins and right now I'm running 7x.010 sac style injectors and a BW 62-65-12 turbo plus all the other supporting mods and on the dyno that put me barely over 500 .... My question is what would be a good injector/turbo combo to get me in the mid 600 range , I would like to stay single charger .... Thanks in advance
Old Jan 5, 2015 | 11:58 PM
wpg6.5's Avatar
I've been looking at a similar set up. A 64 should get you over 600 ish, may be hot depending what all you have. I'm trying to break 600 with a 64/71/14 bs special on 5x14's, 191, and supporting mods. And also may cam it which I think would forsure push it past 600. The 64/71 seems like it may be a bit small to push much more than 600-650 on a 12 valve. I personally am looking into a 467.7 as a single on a steed speed t4, 5x14's, 188/220 cam, hybrid dv's, and probably gonna go with around 20-22 degrees. Hope for around 600 but that's on a 175 horse pump and not the 180 that's in my buddies. I'm hoping it will give me room to grow when I get pump work. And they appear to have a rep for spooling as fast as 66/74's like the silver bullet, and often people say they are faster. A 66 would get you 600 or more. And has been done plenty. theres many choices. Even a 464 or 465 or even the 466 if you wanna go s400.
Old Feb 14, 2015 | 02:26 AM
Just-Another-Dieselguy's Avatar
Wpg6.5 is on point here.
Old Mar 14, 2015 | 09:58 AM
95_ram2500_12v's Avatar
I'm running a 68 and 5x.14s and im just over 600 actually 620 to the wheels with all the supporting mods also
Old Mar 17, 2015 | 05:12 PM
wpg6.5's Avatar
an s468? how does it spool? what housing are you running. i was interested in a 467.7 but wasn't sure i could spool it
Old Mar 21, 2015 | 05:00 PM
94 12valve's Avatar
a 64mm comp wheel turbo with either the 68 or 71 turbine would be my choice
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
