missing on cylinder 4 hits occassionaly
Old Jan 4, 2015 | 01:05 PM
jbxyz's Avatar
Default missing on cylinder 4 hits occassionaly
2002 lb7 duramax, stock, just got the truck. just put 8 new injectors, fuel filter,return line seals, used old high pressure lines but cleaned the **** out of them. i thought it needed injectors but after i put new ones in it still runs rough. with my scan tool i can shut off cyl4 doesnt seem to make it run different. it will occasionally hit up on all cylinder for like a second. tested compression cyl2 is 330ish. cyl4 is 210. cyl6 is 265. couldnt do 8 because i had a home made pressure tester . when i shut off cyl6 it seemed to make a difference. there is no whiter smoke coming out of the oil filler neck but the truck still smokes white?
Old Jan 9, 2015 | 09:33 PM
Walker.B's Avatar
Where did you get the new injectors
Old Jan 9, 2015 | 11:48 PM
detroitdiesel idi's Avatar
Hopefully not from eBay aftermarket remans.....I feel like I've been down this rd before haha
Old Jan 10, 2015 | 04:46 PM
jbxyz's Avatar
from gm
jbxyz's Avatar
there gunuine gm remans
Old Jan 10, 2015 | 07:24 PM
Walker.B's Avatar
start with getting the balance rates checked and if you have someone with a Tech 2 do it have the command max fuel pressure and post results,
could be weak cp3 fuel pump messed up injector harness or a ecm issue
Old Jan 11, 2015 | 12:10 PM
Max fuel pressure can be commanded by unplugging cp3 I'd check the harness
Old Jan 11, 2015 | 12:40 PM
Walker.B's Avatar
Yeah it can but you can't read it without a scanner of some kind and it's a pain in the *** to plug it back in trust me just went threw that finding a leak on the high pressure side
Old Jan 13, 2015 | 12:17 PM
When I do injection pumps on these I go pick up my mom and bring her out in garage to pull the bolts out and put them in BC its a pain in *** with big hands make ur old lady unplug the cp3 haha
Old Jan 15, 2015 | 04:00 PM
Walker.B's Avatar
haha i used a long pair of needle noose to unplug and plug it with the engine put together pain in the *** to plug back in......
