EBPV issue??
Old Dec 31, 2014 | 09:05 AM
OBSBEN's Avatar
Default EBPV issue??
We dont get oo many freezing mornings where I am, but I make sure to plug in when I have a feeling that it will be. This morning (and a few others) I got caught off guard and ended up plugging my block heater in about an hour before leaving. I cylcled my plugs twice and it fired right up with ease. I let it idle for about 10 minutes before leaving. As soon as I increase RPM I can hear a very loud "whoosh" sound that seems to come from the passenger side firewall-floor area. If I let off of the throttle, it continues until it reaches idle. If I increase throttle it continues and the stops abruptly and boost kicks in. It is clear that it has something to do with the turbo due to not building boost pressure. I have read in a few threads about the EBPV sticking or clogging and causing a similar issue, however, no one mentions the increase of RPM. What I have read speaks mostly to idling. I would do the delete, no problem....doesnt bother me. BUT....I have another issue.... My pyrometer quit working suddenly. I have checked ALLLLLLL wiring and even reached out to Auotmeter to get technical assistance from them. Ultimatley, I have no idea why it isnt working....it has power....simply wont read any temperature. To top that off, my Coolant Temp gauge( stock, in dash) never reads above a needles thickness. Would that throw any confusion to the PCM about running the EBPV? I know I'm throwing about 10 needles in the sack..... Any help or guidance would be greatly appreciated!!
Old Dec 31, 2014 | 10:33 AM
joebob3093's Avatar
Moderator
If your worried about the EBPV just unplug it. The coolent gauge could either be a bad sender or a stick open thermostat
Old Dec 31, 2014 | 10:48 AM
OBSBEN's Avatar
Does this valve have any weight in reference to protection of components? For example: If the truck senses too much load during cold weather or before warm up, does the valve open? I thought about unplugging it as well, but wanted to check and see if there may be a reason beforehand. I have yet to test any of the components for the coolant temp, I was just seeing if that may have any reasoning behind the EBPV operation. Thanks for the reply!!!
Old Dec 31, 2014 | 05:21 PM
joebob3093's Avatar
Moderator
the purpose of the EBPV is to help with warm up, so if its not getting up to operating temperature that might be causing it to close more then it should
Old Dec 31, 2014 | 06:02 PM
OBSBEN's Avatar
Alright. Thank you. I changed the fuel filter this afternoon. The cup was rather dirty. I cleaned that out and used some seafood to help clean the tiny parts. Didn't really notice anything afterwards, so I made a video. I am loading it into Youtube now.
Old Jan 6, 2015 | 07:43 AM
OBSBEN's Avatar
Over the weekend I spent a lot of time chasing electrical gremlins. In doing so I removed my PCM and the chip. I cleaned all of the connectors and reinstalled. Runs like a brand new truck. No issues with the EBPV at all, everything functions as it should.
Old Jan 8, 2015 | 08:21 AM
Dak_summers's Avatar
My truck is having the exact same problem. Loud noise until idle or until it builds boost. Where is the plug to unplug the ebvp and what problems will that cause?
Diesel_Daddy6.0
Sep 23, 2015 03:12 AM
JKinni
13
Sep 5, 2015 11:09 PM
Cummins_Power_13
Feb 4, 2015 09:55 AM
norcal6.5
Dec 7, 2014 07:04 PM
Oct 23, 2014 08:10 AM
