need 92 wiring diagram
Old Dec 28, 2014 | 05:07 PM
manns999's Avatar
Default need 92 wiring diagram
So the dude who had my truck before me cut the hell out of the wiring harness on the drivers side of the fender, and now i have several problems like no grid heater, no speedo, no OD, and several other things not working. I also had to rig up something for my alternator. It has a new ecm, but i need to know how to re hook up these wires.
Old Dec 28, 2014 | 05:13 PM
solderjunkie's Avatar
PM your email address and I can send it as a PDF
Old Dec 28, 2014 | 05:51 PM
PDF sent.
If you download the attachment and save it as a shortcut on your desktop, it will be easy to reference whenever you need to use it (without needing to find my email)
Brett
Old Dec 30, 2014 | 06:49 PM
See... this is exactly why I really quit helping people
I sent the guy a PDF of the Mopar FSM electrical manual (all 140 pages of it) and two days later, no "thanks, man" or anything
Old Mar 3, 2015 | 02:37 PM
Heathermichelle Briant's Avatar
I would like to get that info I've got the same problem
Old Mar 3, 2015 | 07:43 PM
gunman41mag's Avatar
Moderator
Old Mar 3, 2015 | 07:54 PM
Moderator
| Repair Guides | AutoZone.com
Old Aug 30, 2015 | 01:46 PM
Chris Moesner's Avatar
I'm bypassing my ecu all together need help with the speedo and he factory tack any pointers would be greatly appreciated
Old Oct 13, 2015 | 11:35 AM
resurrectedauto's Avatar
Default Wiring 1990
Hi new here and appreciate any help i can get.
Am doing a 1st gen project and my wiring is all a mess, truck runs great just everything else is not working.
A little history 4 years back decided to put a 1976 body on an old farm truck beat to hell. it was a 1990 W350 reg Cab flat bed. Also had a 1976 extended cab short bed truck i bought for the engine. Farm truck $2000 and donor truck $500 figured could combine them and make a sweet truck and did and looks great. Except did not take the farm truck apart and i am a body guy. Put it together by just connecting ens that look like they connect and somewhat worked to get from point A-B now want to finish it up
Things that don't work
Heater, windshield wipers, A/C unit and just about everything behind the dash.
have all the body work done and painted even got a little over zealous and installed egt gauge first, transmission gauge fuel pressure gauge and oil, an
intercooler, DDP 50hp injectors, 40hp fuel pin, 3800rpm spring, larger intake and 4" turbo back exhaust. had tranny rebuilt and hope to one day do a manual swap.
Admitting defeat i cant figure the wiring out, am located outside of Memphis, Tn and would like to get the truck done. Have gone to some shops and they have quoted me 3000+ because they would have to do so much research into it.
Any help within 500 miles of Memphis on an awesome 1st gen wiring guy or gal who is not going to dry up my wallet.
Thank you for reading that LONG RUN on post with lots of grammar errors.
Old Dec 9, 2019 | 02:19 AM
Maddog1990's Avatar
id tell you thanks a thousand times if you could send it to me krawlthewarriorking90@gmail.com I’m having hell due to previous owner
