83 chevy 6.2 Dies after 3 minutes
Old Nov 27, 2014 | 08:07 PM
DanielC559's Avatar
Default 83 chevy 6.2 Dies after 3 minutes
Hello DB community. I have a very frustrating problem. My 83 6.2 diesel starts and then dies after 3 minutes of running. I checked the small filter in the valley after it dies and it's completely empty. I verified that my lift pump is working and I changed all hoses going to the tank because I thought it might be sucking air or something. Restarted truck after I filled the fuel filters and I got the same result. Any help would be much appreciated. Thanks
Old Nov 28, 2014 | 03:20 PM
Mayhem's Avatar
Have you looked at the sending unit and the inside of the fuel tank it's 31 years old it is possible it may have a rust hole in the pick up tube.
Old Nov 28, 2014 | 06:07 PM
DanielC559's Avatar
Do you think I can verify the hole in the pick up tube by filling the tank to the top and seeing if it stays on?
Old Nov 28, 2014 | 08:01 PM
Floyd400's Avatar
Sounds like air getting in. Could you try running a hose from a can of fuel to the lift pump to rule out the tank sending unit? Best I can think of at the moment, good luck!
Old Nov 28, 2014 | 08:24 PM
DanielC559's Avatar
I tried running an electric fuel pump with an external fuel source and I get the same results.
Old Dec 7, 2014 | 07:10 PM
racer55's Avatar
Might be a restriction in the fuel return?
Old Dec 7, 2014 | 08:38 PM
DanielC559's Avatar
Do you know how I can check for a restriction in the fuel return?
Old Dec 8, 2014 | 06:20 AM
racer55's Avatar
Take the cap off the fuel tank and blow low pressure air back into the tank dfrom the IP end of the return line.
Jackthesmallengineguy
Nov 12, 2017 01:25 PM
drice3050
Apr 26, 2015 09:06 AM
UniqueCopy
Dec 14, 2014 11:37 AM
Caveman94
Dec 8, 2014 12:21 PM
Oct 16, 2014 07:10 PM
