heavy towing towing mods
Old Nov 23, 2014 | 10:40 AM
amztroyer's Avatar
Default heavy towing towing mods
I just finished the engine swap on my F550, the 2000 24 valve engine is completely stock, the truck has 488 rear end gears and a six speed manual transmission runs about 2k@55mph.
I am looking to get more power and mileage, I get about 9 mpg pulling 25k wide loads.
here's what I'm thinking after bit of research, tS performance MVP, 50 HP dynamite diesel injectors and gauges, please chime in with your thoughts and opinions
Old Nov 23, 2014 | 03:16 PM
Just-Another-Dieselguy's Avatar
How about Coffey 7x.010 sac's
Head studs
62/71/14
Dual disc clutch
And an edge comp box
And gauges
Old Nov 28, 2014 | 12:53 PM
jigabop's Avatar
ditch the 4.88 gears for 3.73 or 4.10
forget DDP injectors... waaay overpriced. DFI injectors work much better.
edge ez will give some timing for a bit better economy. throw a boost elbow on the stock turbo and adjust it to allow 35psi boost.
gauges are a must. EGT, boost, fuel pressure.. fass 95 lift pump will help keep the fuel pressure up. need to be running no less than 10psi at ALL TIMES that the engine is running. 14+ ideally.
Old Nov 29, 2014 | 11:43 AM
amztroyer's Avatar
thanks for the input, Ive read reviews from ddp, cpp, dap, and dfi, with so many opinions its hard to make a decision, ddp sounds like the winner because of 8 holes and their honing process, but I've read reviews saying they like dap injectors better(cleaner cooler) doesn't make sense to me.
Old Nov 30, 2014 | 07:06 PM
There is a lot of injector company's. DFI makes a good one. I Run CPP 7 hole sacs.
Next set will be Haley Performance sticks.
Or something from Weston
Old Dec 2, 2014 | 01:13 PM
jigabop's Avatar
I run 6x.013s from Weston Shupe and love them. He gave a great price as well...
I got my complete injectors from Weston for $650 for custom 6x.013 micro blind SAC injectors.
DDP wants $500 for 50hp nozzles only... WASTE OF MONEY!
BTW: DFI (Chris) gets their nozzles from Weston Chris is a good guy and puts together quality stuff.
Old Dec 22, 2014 | 10:30 PM
jkidd's Avatar
A small programmer, and some of our 60-100hp injectors. I suppose you could go up to 125HP SAC and keep the programmer on a lower setting.
assuming you have the nv5600 the 4.10 gears will tow much better than 3.54.
If you are towing than much spend $700 or so and get an exhaust brake!
2004LB7
29
Feb 29, 2016 06:00 PM
12 valve 97
5.9L 12V Performance
21
Jan 27, 2016 04:59 PM
corksil
Aug 2, 2015 10:19 PM
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
Sep 29, 2014 12:40 PM
