won't start
Old Nov 18, 2014 | 11:51 AM
garbuster's Avatar
Default won't start
I have a 99 dodge. It has an airdog 150 on it and a edge juice with attitude. This is a daliy driver. Yesterday goig home from work it started missing real bad. Every time it would hit it would puff out blue smoke out the exhaust then it died and won't start back. Kind of sounds like it does when I change fuel filter and takes a minute to get fuel. It just turns over and never tries to crank. Getting 18lbs of fuel pressure at injector pump. I haven't checked for codes. I have a buddy coming over tonight to do that. Just thought I'd see if any body has any ideas. Thanks in advance
Old Nov 18, 2014 | 06:34 PM
Redtruck-VA's Avatar
Blue smoke? wouldn't that mean crank case oil? turbo seal?
Old Nov 18, 2014 | 09:34 PM
Just-Another-Dieselguy's Avatar
Let us know what codes you pull.
Where do you have the fp sending unit?
Old Nov 19, 2014 | 12:59 PM
garbuster's Avatar
Only code its showing is glow plugs. Haven't had an issue with it cranking until now. I am getting fuel to injector pump. I cracked open #1 injector line and didn't get any fuel while turning motor over. Is it injector pump or could it be electronic
Old Nov 19, 2014 | 01:53 PM
That truck does not have glow plugs...
Old Nov 19, 2014 | 02:06 PM
Is there power to your FSS?
Old Nov 19, 2014 | 05:23 PM
garbuster's Avatar
What is FSS
Old Nov 19, 2014 | 05:57 PM
Originally Posted by garbuster
What is FSS
I'm not very knowledgeable but as I understand it, it's a solenoid that closes off the fuel when the ignition switch is turned off. If it wasn't activated (opened) then the engine would only crank and not start. FSS=fuel shutoff selenoid
Old Nov 21, 2014 | 03:49 PM
his truck is a 99 that is a vp44 truck, so it does not have a fuel shutdown solenoid. i want to see fuel pressure to the IP before i say anything else
Old Nov 21, 2014 | 04:19 PM
Sorry, there is a lot I don't know... Thought it was worth a try..
