Lb7 won't start
Old Nov 16, 2014 | 02:42 PM
Caleb C's Avatar
Default Lb7 won't start
Ok I didn't have funds for new injectors. I was getting fuel in the oil. No missing or smoke. I pulled the injectors found blown o rings on the drivers side front two. I cleaned the injectors put a tiny bit of rvt on the threads re tightened them got new seals and o rings installed them. Rebuilt the filter housing. Primed cracked lines primed again. I can only get it to run a little with gas on a rag. I have been priming and cranking for several hours now. All fuses and connections look fine. Any body got a trick I haven't thought of
Old Nov 17, 2014 | 02:06 PM
2500HeavyDuty's Avatar
the injectors are compression sealed, rtv wont do anything for ya. they are probably failed internally
mlknutzen
Oct 1, 2015 10:56 AM
Paladin
Jul 26, 2015 03:59 PM
ronstop
Feb 26, 2015 09:48 AM
damanrescue
Dec 2, 2014 04:12 PM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
