Cp3 to change or not to change
Old Nov 16, 2014 | 10:56 AM
crusty's Avatar
Default Cp3 to change or not to change
My 2003 cummins has 320,000 miles on the CP3, I am changing the fuel injectors and wondering if I should change the CP3 at the same time, not sure what the life expectancy of these pumps are, mine has always been fed with the fass fuel system and new filters any idea how long these pumps last,
Old Nov 16, 2014 | 05:42 PM
AHolt's Avatar
There is no reason to change, unless you are having
problems with it.
Old Apr 20, 2015 | 07:08 PM
The_Diesel_Whore's Avatar
me personally if its still flowing good and all then i wouldnt. but if you was gonna put new ones in then you might wanna swap it out to while everythings apart
Old Apr 23, 2015 | 10:02 AM
jkidd's Avatar
IF you are going to bigger injectors an older CP3 may not keep rail pressure up where you need it to be. If you are staying stock and Rail pressure is good then keep it as is.
Old Apr 26, 2015 | 03:31 PM
dangerous1965's Avatar
Change it better than being stuck out in the boonies!
wlofton
11
Jun 26, 2018 08:58 AM
nomoney
Jun 16, 2015 08:16 AM
ctjkelley
Jun 3, 2015 06:01 AM
schwier94
17
Apr 7, 2015 03:16 PM
schwier94
Mar 24, 2015 12:18 PM
