6.9 swap over heating
Old Nov 11, 2014 | 08:06 PM
Bigredpowerstroke's Avatar
Default 6.9 swap over heating
I bought a 1978 f150 with a 6.9 idi swapped in it. But im having a problem with overheating at idle. When i drive the trucl stays no higher than 198 or so but when im sitting at a light pr just idling itllget very hot over 215 anx i have to shut her off or start drivimg again for the air to cool the radiator. I replaced the thermostat already with a motorcraft one and didnt really change much. It is the original radiator from the 78 so im wondering if that could be the proble, not big enough or clogged up. The fan seems to be in working order. Please help thanks
Old Nov 12, 2014 | 01:20 AM
Sycostang67's Avatar
There's a good chance that radiator isn't up to the task. The radiators in my 93 and 86 were both really clogged and still wouldn't let the trucks overheat. Do you even know what size motor that radiator was cooling? The IDI cooling system should hold 8 gallons of fluid as well.
Old Nov 12, 2014 | 06:44 AM
I dont know what motor but i had to make a fan shroud because the fan from the idi is alittle bigger than the radiator. Im thinking mabe an all aluminum radiator from a 460 or 7.3 should work. Is there any way to tell if its clogged?
Old Nov 12, 2014 | 03:33 PM
I could tell mine were clogged by looking in the cap. Most of the tubes I could see had crud in them. If your fan is bigger than your radiator, it sounds like you have a small block gasser unit. A big block radiator might work as I am sure you would have to do some modifications to fit the diesel unit in that core support.
lvnlrge63
Aug 23, 2015 09:57 PM
yzrider250
Diesel Engine Conversions
Aug 10, 2015 11:33 AM
ReckONE
Feb 25, 2015 09:41 AM
Jgloveracob
Nov 16, 2014 07:27 AM
tumble72
Nov 10, 2014 08:41 PM
