Coolant in Oil, But NO oil in coolant. Maybe waterpump??
Old Nov 9, 2014 | 04:49 PM
gmcmanis's Avatar
Default Coolant in Oil, But NO oil in coolant. Maybe waterpump??
Im getting a slight amount of coolant on the oil cap, and the coolant level is slowly going down. So i just top it off every so often. My oil is not turning "cloudy", my oil is still very clean for a little over 5000miles on it. I pressure tested my coolant system, both HOT and Cold,....it dropped less than 1PSI in about 30 minutes on both Hot and Cold. I did some research and found that somebody else had that issue and the dealer said it was waterpump seal, and the problem went away after water pump replacement.
Tobyk
Jul 7, 2015 08:01 PM
Bull Grunt
May 15, 2015 09:55 AM
Bull Grunt
May 3, 2015 06:38 AM
coors_man_2005
Dec 15, 2014 10:23 AM
97f-250
Nov 23, 2014 08:08 PM
