stummped by this
Old Nov 6, 2014 | 06:02 PM
bobbyearl's Avatar
Default stummped by this
I have an 04.5 Cummins. Yesterday it started missing for about 10 miles. Then it stopped missing but had no power. It would pull itself but was weak. The computer says injector issue and low boost. Can anybody help?
Old Nov 6, 2014 | 06:54 PM
FlyingDutcman's Avatar
not sure if this will help or not, but i hope for your sake it does!
04.5 flash update problems - Dodge Cummins Diesel Forum
are there any other codes? pull the injectors and have them tested? make sure the lines and feed tubes are tight and not sucking air anywhere? pressure gauge on the rail or before the cp3?
Old Nov 6, 2014 | 07:10 PM
bobbyearl's Avatar
Thanks Dutchman. I don't know what happened but I was looking for air and fuel leaks. Cranked it up and the code went off and it's churning and has the power it did before.
Old Nov 6, 2014 | 09:35 PM
Bigg Redd's Avatar
That may be the beginnings of an issue(s) thats about to rear its ugly head, down the road.
Old Nov 7, 2014 | 05:31 AM
bobbyearl's Avatar
Don't talk like that bigg redd. I really hope not. But if it is keep checking here. I'll be letting you guys know.
Thanks again for help guys
Bobbyearl
Old Nov 7, 2014 | 11:43 PM
Bigg Redd's Avatar
Bobbyearl
Im just speaking from experience. I dont mean to worry you, but I think Its too late for that.
