95 motor swap into 93
Old Nov 2, 2014 | 08:07 AM
88ford01's Avatar
Default 95 motor swap into 93
I have a 95 gmc with 6.5 and bought a 93 gmc with 6.5 and want to put my motor in it besides having to use the pump outta the 93 is there anything else that needs to be done?
Old Nov 2, 2014 | 08:28 AM
racer55's Avatar
The only thing off the top of my head is to be aware that when you need a replacement balancer it will only be able to use one from 94+,the reluctor on the timing gear takes up space so the balancer snout is shorter than the 93.
Also the CPS will not be used obviously.
Old Nov 2, 2014 | 03:28 PM
88ford01's Avatar
So just leave the cps sensor in motor nothing will plug into it and do the balencers have issues on these trucks?
Old Nov 2, 2014 | 05:02 PM
racer55's Avatar
Yes on the CPS and yes the balancers and frt drive pulleys are known to loose their bonding-inspect them carefully and replace with AC Delco or Powerbond from Oriely's if needed-otherwise a broken crankshaft will bin your future.
Old Nov 2, 2014 | 06:02 PM
88ford01's Avatar
Ok thanks for the help
