fuel problems?
Old Nov 1, 2014 | 12:50 PM
LTreis702's Avatar
Default fuel problems?
I have a 97 gmc with 6.5l its been dying when I take my foot off accelerator and sometimes surges or cuts out under hard acceleration any ideas?
Old Nov 2, 2014 | 08:36 AM
racer55's Avatar
Copy and paste this to your next reply and edit in the answers to the questions and results of the tests that need to be done.
The more info you can provide the better the answers you will get in return:
The Diagnostic Checklist:
Please fill out to best of your knowledge.
1. Describe the problem you are having in detail:
2. Year of truck/engine.
3. Odometer reading (indicate miles or kilometers).
4. Indicate the model number on the Injection pump (starts DS4 or DB2......).
5. Indicate if you know if it’s a 1500, 2500, 2500HD, 3500, 3500HD.
6. Do you have an EGR on the engine? (An F or an S engine code 8th VIN digit)
7. Air Filter condition (visual check).
8. Fuel filter condition (freshly changed, mileage since changed).
9. Location of PMD/FSD? (ex. on pump/remote over intake, behind bumper).
9a. If remote mounted, describe wiring harness (homemade or purchased from which vendor).
9b. Indicate the location and condition of the FSD/IP grounding wire.
10. Outside Temperature (C or F). _____ °
11. Service Engine Light while running?- on/off/intermittent
11a. Service Engine light does glow during start/cranking/bulb check: Yes/No
12.Have you scanned for engine codes? Yes/No
12a. List exact results on engine codes.
13. Condition of Battery terminals (removed, cleaned and tightened).
14. Known condition and age of Batteries.
14a. Are batteries a matched set of same age?
15. Condition of Major Grounds (removed, cleaned and tightened)
15a Have the batteries been individually load tested?
16. Does engine crank, or "turn over"?
16a. Does engine start and run?
17. If engine does not start- Crack injector line: do you have fuel? Yes/No
18. Does your Wait To Start light come on?
18a.Number of seconds WTS light is lit.
19. Engine Cranking speed (if you have an accurate tachometer).
20. Are you experiencing Stalling?
20a. Describe the event (upon startup only, down the road, hit a bump, etc...)
20b. Do you notice loss of dash or instruments?
21. Check turbo inlet and air filter for obstructions.
22. In a no-hot start, pour a bottle of room-temp water on the injection pump. Does it start now?
23. Lift pump test - Describe results.
24. Upon cold start, does the radiator hose get hard quickly? Yes/No
25. Upon cold start, do you have excessive white smoke? Yes/No
26. Do you have excessive cranking time before the engine starts? Yes/No
27. Have you used the block heater? Does it affect engine starting? (only try for starting problems).
28. Are all glow plugs in proper working order?
29. During hard acceleration, do you have excessive black smoke? Yes/No
30. Do you have any unusual exhaust smoke issues?
31. Turbo check out - Pass/Fail
32. Indicate fuel that you are using: Bio-Diesel, #2 Diesel, SVO/WVO, other
32a. If running Veggie Oil fuel setup, indicate details of your conversion (homemade or packaged system).
33. Are you using any fuel additives? If so, please list.
34. Upon unscrewing fuel cap, do you have a large vacuum formed in the tank? Yes/No
35. Do you have any service history available that might pertain to the problem you are having?
36. Please indicate any modifications to the vehicle that might help us diagnose better.
Old Nov 2, 2014 | 10:46 AM
LTreis702's Avatar
thanks I tested the LP and found out it was bad so im going to replace it and if im still having problems I will run threw the checklist thanks for taking the time to send it to me
gillespie3033
Chevy/GMC Duramax 01-04 LB7
29
Jun 25, 2015 03:51 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
J. Nick
Apr 24, 2015 01:13 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
