93 6.5 no fuel
Old Oct 19, 2014 | 10:18 AM
Gorder14's Avatar
Default 93 6.5 no fuel
I just had the lift pump changed in the truck and ran fine for awhile but now it won't start just cranks and blows white smoke and sometimes will fire up and only run for a couple seconds? I was told there is some kind of sensor that can go bad and cut off the fuel supply anybody know what that would be
Old Oct 19, 2014 | 11:05 AM
racer55's Avatar
The oil pressure switch is what supplies power to the electric lift pump when the engine is running.
AC Delco ONLY for replacement,and google "OPS relay Mod" and install for long term reliability.
The symptoms you describe also show that you have an air leak somewhere between the fuel level in the tank and the IP.
Old Oct 22, 2014 | 02:58 PM
GASMAN12's Avatar
The op sensor just doesn't take care of the oil pressure it works the lift pump to.your better off getting one from ss
diesel u can get one from the parts store won't last long
Old Oct 22, 2014 | 07:43 PM
racer55's Avatar
Do not deal with SS Diesel unless you like having 0 customer service after the sale,according to what I have read many times-never dealt with Walt myself to confirm because of similar warnings early on..
Your local GM dealer, Rock Auto or get the local parts store to special order AC Delco,or part # D1808A or GM part#12555492.
Old Nov 2, 2014 | 07:13 AM
Gorder14's Avatar
Thanks guys I got an op sensor now just gotta find some time to put it on...what's the procedure on these 6.5's to prime them? It's been sitting awhile but I've never primed one before?
Old Nov 2, 2014 | 08:02 AM
racer55's Avatar
The manual says to bleed the fuel filter and just crank for no more than 15 seconds followed by a 1 minute starter cool down period,repeat as needed.
I like to crack an injector fuel line loose to speed things up,tighten once running or after first shutdown.
penley`
Jun 7, 2015 04:38 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
Phoenixforsigns
Dec 15, 2014 10:50 AM
