2x4 to 4x4 conversion
Old Oct 7, 2014 | 10:05 PM
bypass-21's Avatar
Default 2x4 to 4x4 conversion
Hi everyone! Pretty new to the forum but im filled with a few questions on a recent project i got here. Shes a 1997 Chevy k3500 dually with a 6.5T in her. It comes fairly loaded, minus 4 wheel drive. I want to at the very most put in the stock set up from maybe a junk yard 4x4 set up of the same year and model and drop it in, but i have no idea if any modifying is needed or all together what parts i need to ask form from my hook up at my local junk yard. Im a Technician a GM shop so i have access to shop tools if needed.
thanks again everyone!
Old Oct 8, 2014 | 05:33 AM
Mayhem's Avatar
K series is 4X4 C series is 2X4 and to do that you will need a 4X4 frame due to it's having torsion bars and 2X4 does not.
Old Oct 8, 2014 | 07:45 AM
burnhedge's Avatar
Are you wanting solid axle or ifs?
Old Oct 8, 2014 | 11:56 AM
bypass-21's Avatar
if i remember correctly, the k3500 came with an ifs, so that would probably work better on my c3500 for a 4x4 set up right? I would like to try a solid axle setup, but that would be too much of a pain installing.
plus stuff like torsion bars can be installed in the truck if im not mistaken.
Old Oct 8, 2014 | 01:08 PM
detroitdiesel idi's Avatar
Should be able to. The torsions dont attatch to the frame they attach to a xmember tht attatches to frame..but itd b alotta of wrk and $ trans driveshafts front axle gearbox list goes on but if u did id go straight axle dana 60
Old Oct 8, 2014 | 01:21 PM
bypass-21's Avatar
So just so i know what to ask for. What kind of parts should i make a list for?
Old Oct 8, 2014 | 01:47 PM
burnhedge's Avatar
Your best bet is to search Craigslist for a donor truck. Buying parts one at a time will cost a fortune.
Old Oct 8, 2014 | 01:51 PM
bypass-21's Avatar
Might it be easier to get the parts from the car yard then? i know somebody who works there and can set me up with some things
Old Oct 8, 2014 | 01:58 PM
bypass-21's Avatar
lets see whats necessary.
A transfer case.
A new front and rear drive axle
A front ifs diff and axle
New wheel hubs?
New abs sensors?
Torsion bars
A mode shifter
and a hole for it to go in the floor?
is that all or is there more needed?
Old Oct 8, 2014 | 03:34 PM
burnhedge's Avatar
Auto or 5 speed? I know you can't bolt a transfer case up to a 2wd NV4500. Not sure about automatics.
