Chevy/GMC Duramax 07.5 -10 LMM Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines
Problems please help
Old Oct 4, 2014 | 08:22 PM
FtpDirty's Avatar
Question Problems please help
2008 GMC Sierra SLT 272351km
Ok so here's the deal.
As soon as I shift into drive or reverse with my foot on the brake the truck wants to go, I can barely hold it back sometimes, if I am on gravel or wet pavement the tires slip and spin. This is the same when coming to a stop. Always rough shifting to N, P, R because its constantly engaged.
2nd symptom
If I stand still leaning on a curb my truck will not climb the curb and boggs right down when I give acceleration and blows black smoke. On pavement will not do a burn out unless I go into rolling burnout and then **** lets hell loose.
Transmission heats up pretty good as well and whines as soon as put into drive or reverse
Its performance tuned from the dealership, dyno at 495 hp, only after market piece is the exhaust MBRP. this problem has only started 5 days ago.
Air filter is good, oil changed, fuel filter changed, transmission filters and fluid changed belt is good. No codes, brakes are good
Transmission is smooth, shifts smooth, all the gears work, trailer mode manual shifting
I know can't be the only person to run into this problem before. I suggest the torque converter. but trying to figure this out before paying money.
Thanks
Old Oct 9, 2014 | 09:07 AM
Motorops's Avatar
FormerVendor
How hot are we seeing the transmission getting? and how does the trans shift when you are driving it normal?
Old Oct 9, 2014 | 09:19 AM
FtpDirty's Avatar
Shifts smooth, highest toe rather stuck in traffic. Was 113c
Old Oct 9, 2014 | 09:25 AM
Motorops's Avatar
FormerVendor
okay that would translate into 235F. Does it drop back down or king of hover there?
Old Oct 9, 2014 | 09:27 AM
FtpDirty's Avatar
If I get driving again yes it drops down , that was stuck in gridlock for 20 min
Old Oct 9, 2014 | 09:37 AM
Motorops's Avatar
FormerVendor
does it feel that the Torque converter slips at all? Are we getting any codes?
Old Oct 9, 2014 | 09:42 AM
FtpDirty's Avatar
It does now, I'm pretty positive it's the torque converter, been getting a little worse the last couple days. Talked to transmission shops here and they think the transmission isn't unlocking when I come to a stop which in turn would make the problem the converter. No codes
Old Oct 9, 2014 | 09:49 AM
Motorops's Avatar
FormerVendor
Sounds like all your symptoms are leaning toward the Torque converter. How many miles are on the truck?
Bloom12valve
Oct 9, 2015 03:40 PM
J. Nick
Apr 24, 2015 01:13 PM
DODGEARMYGUY
Mar 3, 2015 11:40 AM
JRB1960
Dec 1, 2014 09:24 PM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
