04 ford f350 6.0 no start ????????
Old Sep 14, 2014 | 08:05 PM
JWH6.0's Avatar
Default 04 ford f350 6.0 no start ????????
04 6.0 ran fine this morning got to a stop sign seemed like it was running rough a little noticed on takeoff power was down a little then had to put my foot into more till it finally just stalled . thought it was the crank sensor since shows no RPMs on dash but no oil pressure either on gauge replaced CPS still no change . took out the oil filter and its bringing up oil into the housing . I hooked up a scan tool and it says no FICM sync or no sync between the cam and crank sensors . Ive unplugged the IPR under the turbo and still no start either . It will crank but no start and heck i dont have the money for a dealer to look at it !!!!!!! could my HPOP have gone out ? There is no mods to it except cat delete and muffler delete its at 141,000 now and i just had the oil changed at the dealer where i got it from yesterday . Its not used to pull its just a daily driver thats it
And yes ive checked the FICM voltage to it doesnt drop below 47.8 and stays at 48
HELP .......... Im pulling hair out trying to figure out the cause of the problem !!!!!!!
Cavnar
Sep 9, 2015 07:18 PM
ish1521
Aug 26, 2015 08:42 PM
keith63
6.0L Performance
Mar 18, 2015 12:35 PM
