Need help! New owner of a 1989 f250 xlt lariat single cab 7.3l idi 216 k
Old Sep 11, 2014 | 10:09 PM
seabass89's Avatar
Default Need help! New owner of a 1989 f250 xlt lariat single cab 7.3l idi 216 k
Hi everyone,
I just bought a new truck and fell in love with it. It's a 7.3l idi 1989 f250 xlt lariat single cab 4x4. I'm pretty new to the diesel world and need some advices from passionate people like you.
Things I need to fix:
- glow plugs ( problems with cold start)
I would also like to know what i should be doing to keep this truck running for a long long time. I am motivated to learn from you guys and gals and doing my own mechanical work within my abilities.
So what should I look for, anything I should replace before the winter (prevention stuff) ? What kind of oil is best to use with this kind of truck?
Lots of things I need to learn, if anyone as a little bit of time to teach me a thing or two that you learn threw the years I would be really grateful And i would like to pass on this knowledge to others.
Thanks everyone!
Old Sep 11, 2014 | 11:08 PM
4x4manonbroke's Avatar
for your Glow Plugs ( GP's ) .. You will need to start by doing a Contunuity test on each GP unplugged from the wiring ..
Next Check for voltage @ each plug wire .. not while plugged into the GP .. ( positive on the power wire @ gp .. the Ground on the block ..
If you get no power the GP controller may be to blame .. or check grounds and such ..
I ran Royal purple 15/40 full synthetic and gained 1.5 mpg alone .. I also Installed a 14X6" K&N Air Filter with a small riser ( carb spacer ) .. other wise it might arc out on the GP controller ..
Old Sep 12, 2014 | 06:41 AM
seabass89's Avatar
Default Thank you
This is great! Thank you for your time, I will let you know how it goes. Have a great day!
Old Sep 12, 2014 | 08:33 PM
pkcole
For Sale
Nov 20, 2014 08:11 PM
