Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
6.4 limp mode?
Old Sep 9, 2014 | 07:56 PM
BrandonW5's Avatar
Default 6.4 limp mode?
Hey guys at work we have a 2008 f550 service truck obviously a 6.4 and its got a 6 spd manual. Not sure of miles somewhere around 70000. Lately it will intermittently act like it's in limp mode or something but has no dtc or anything. It won't build more than about 15-20 lbs of boost and is just gutless. If you pull over and shut it off and start it again it runs just fine. But if you sit and idle for a while it will do it again or if you short shift out of low it'll do it. All emissions are in place on truck and it will go through a regen just fine or at least according to the dash it does. Any thoughts? Thanks!
Old Sep 29, 2014 | 05:50 PM
liftaford6.4's Avatar
Default Goin limp
Might want to check the water seperator sensor. sensor might be bad or the fuel water seperator resevoir needs cleaning. open the water seperator drain valve and see if anything comes out. If not it's gunked up.
6.4 king ranch
Apr 15, 2015 03:53 AM
ClintD.
Chevy/GMC Duramax 06-07 LBZ
Mar 23, 2015 04:37 AM
syctaz
Mar 3, 2015 09:23 AM
To fast
Chevy/GMC Duramax 04.5-05 LLY
Feb 10, 2015 09:30 AM
Brandanllewellyn
Oct 20, 2014 08:09 PM
