new with the 6.5L
Old Sep 8, 2014 | 07:38 AM
Willlift's Avatar
Default New with the 6.5L running terrible
Hey guys I need help. I'm new with the 6.5 turbo diesel. I got the truck about a year and a half ago. I noticed it has had a hard start every time I started truck. I've changed glow plugs and still same results. Now just recently I started noticing some blow back and oil shooting from dip stick, and also ses light came on. Now just on Friday evening truck started running real rough and a boat load of white smoke started pooring out very with a rich fuel smell. Can someone please tell me what all this could be?
Old Sep 9, 2014 | 02:59 PM
racer55's Avatar
Could be an injector has blown out the tip.
they should be changed as a set,all 8 at once when they are rebuilt/replaced.
First get the codes checked,google paperclip code check and then post your codes here-the online code lists are not 6.5 specific and do not always apply-we can point you in the right direction.
Your hard starting might be a fuel leak from seals in the filter housing,or a lift pump problem?
lots of testing for you to do.
Old Sep 9, 2014 | 03:08 PM
Willlift's Avatar
Thank you for the information. Yesterday I Took it to the shop and codes 35-36 came on saying injector pump is bad. Now when I drove back home yesterday evening I started experiencing a knocking sound. Could that be the lifters possibly going too?
Old Sep 9, 2014 | 03:46 PM
racer55's Avatar
Unlikely that lifters are going but possible?
Probably wouldn't be able to hear them over a running diesel though?
Old Sep 10, 2014 | 01:39 PM
detroitdiesel idi's Avatar
Bad injector pump sometimes makes a rattly loose marbles like sound a knocking cld b injector tip if its a manual trans cld b throwout bearing( wld sound like rod bearing) blowby cld b clogged cdr valve or low compression which would also be a hard start condition like you mentioned
sjslhill
Jul 22, 2015 01:02 PM
HardLuck
Jun 24, 2015 08:04 AM
HeavyChevy95
Jan 11, 2015 04:31 PM
95 Sub
Jan 3, 2015 07:44 PM
duanedwc
Dec 13, 2014 12:36 PM
