i need help
Old Aug 29, 2014 | 03:18 PM
94sixfive's Avatar
Default i need help
I have a 94 Chevy k1500 and its running like ****. I runs fine when it first starts for a while but as it warms up it gets s rough idle in controllable throttle no power and as of right now I can't start the truck with out the rpms running away to 3,000
Old Aug 29, 2014 | 04:22 PM
Mayhem's Avatar
PMD get a new one and if it is not relocate it.
Old Aug 29, 2014 | 04:57 PM
94sixfive's Avatar
thank you I'm new to the truck. and it was already moved but only to the top of the manifold I was thinking it was the pmd but I'm not sure
Old Aug 29, 2014 | 05:30 PM
Daniel Leipart's Avatar
ya move it behind the bumper or at least to the fender. you will probably have to get a longer extension wire
Old Aug 30, 2014 | 10:19 PM
racer55's Avatar
Might want to do some legwork first like checking codes?
Search here for Diagnostic checklist-fill it out best you can along with the results of the tests it asks be performed.
the more diagnostics you do the better answers you can get from us to help solve the problem.
Since it's you hands on the truck it's up to you to help us help you.
Old Sep 4, 2014 | 01:21 PM
detroitdiesel idi's Avatar
J Could also be injector pump head warped and as it heats up its out of its tolerances
Old Sep 4, 2014 | 05:34 PM
racer55's Avatar
Warped rotor does not cause run away that I know of-if anything it causes hard hot starts.
