6.5 center mounted turbo into 84 chevy
Old Aug 23, 2014 | 01:35 PM
460willy's Avatar
Default 6.5 center mounted turbo into 84 chevy
I have been building a truck for my daughter for the past 5 years its built on a 1/2 ton frame so no high torque newer diesels would work well. I picked up a 1999 chevy van with a center mount turbo anyone ever tried the swap. I do have a 3 inch body lift which will help alot. I also know I will be changing to a mechanical injection pump . Anything else I might be missing
Old Aug 23, 2014 | 02:35 PM
racer55's Avatar
will likely need a mechanical wastegate actuator/turbomaster when you delete the electronic controls.
As long as you have room for the down pipe from the turbo it should work ok.
Chevy6.5/2500hd
Jun 21, 2015 02:37 AM
timmyd
Jun 8, 2015 11:35 PM
klein444
Feb 27, 2015 01:53 PM
Snoobly
Dec 11, 2014 11:59 AM
cde345678
Nov 15, 2014 05:28 AM
