1st gen to chevy nv4500
Old Aug 22, 2014 | 12:19 AM
Irish_Alley's Avatar
Default 1st gen to chevy nv4500
i plan on using a 4l80e for my cummins 4x4 crew cab. but just running ht eideal though my head, found a gm nv4500 for 800 and i have the chevy adapter plate for my cummins. so what flywheel would i need? i know you can buy the whole kit for 1200 but since i have the adapter im trying to do this on the cheap side since i have some stuff already
Old Aug 22, 2014 | 06:42 PM
novapat's Avatar
If its the factory cummins to chevy that they used in the bread trucks they use there own flywheel ,bolts ,hub, and waffle plate for that set up.. The bad part about them is the starter is on the pass side of the vehicle by the turbo and if you run ac its a pain but can be done.. I did it on mine.. you can pick up the factory ones for like 700/800 bucks..i run the th400 trans with a gear vendor.
Old Aug 22, 2014 | 10:51 PM
yeah its a bread truck one. it did have a th400 then the po blew that up and decided a 4l60 would work. it might of help up longer but they didnt hook up the kick down cable. so the flywheel ,bolts ,hub, and waffle is about 7-800 plus the trans, ouch
Old Aug 23, 2014 | 12:18 AM
so whats the "technical" name for this style cummins. if i go looking for a clutch lets say on southbend, what would i search under?
Cdog121
Nov 16, 2015 01:49 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
ajpt6.9
Dec 4, 2014 12:06 PM
myago92
Oct 17, 2014 08:50 AM
93 gulfstream
Oct 5, 2014 09:46 PM
