VE pump leak through breathing hole
Old Aug 18, 2014 | 11:46 PM
Noel254's Avatar
Default VE pump leak through breathing hole
I have a leak in my injection pump. I thought it would be the diaphragm as it leaks right under it, after replacing the diaphragm the leak continued. diesel leak is between the diaphragm and the spring through the breather hole idk what it could be! I don't think it could be a gasket bc it's leaking thru that breather hole. Any help or advice would be greatly appreciated. Thanks for your help
Old Aug 19, 2014 | 04:49 PM
novapat's Avatar
The o ring around the small fuel pin is leaking.. likely to happen if a aftermarket fuel pin is used because the little pin that rides in the fuel pin that attaches to the diaphragm is deeper. there is some good diagrams on here for the breakdown on the pump to help understand what I am trying to explain (Stickeys)
ctjkelley
Jun 3, 2015 06:01 AM
southern dieselnorth zip
May 18, 2015 01:02 AM
ItsAChummins
May 15, 2015 05:02 PM
moneypitk5
Feb 12, 2015 11:01 AM
Gizmo52
Oct 27, 2014 07:32 PM
