Kubota v2203 with tranny and transfer case out of my ranger
Old Aug 9, 2014 | 06:53 PM
wyoranch's Avatar
Default Kubota v2203 with tranny and transfer case out of my ranger
OK guys, I'm gonna be putting a bigger Kubota in my ranger and an auto so I'm selling my entire drivetrain. Direct injection 2203 Kubota, had 1800 hrs when I got it. Has 10k miles since swap. Will include everything to drop into a ttb ranger including driveshafts if you need them. Comes with an electric shift or manual shift transfer case, whichever you need. Has all accessories including ac compressor, but compressor leaks. Isuzu NPR alternator, bobcat throttle linkages, turbo, intercooler, etc. 830-391-4799
Motor has been very reliable, starts every time. The problems it has: needs a new turbo drain line, where I originally mounted it the rubber line was touching the exhaust manifold and it burned it, weeps a small amount of oil. Needs new gaskets on the exh manifold to turbo adaptor, small exhaust leak. Last thing is it really needs a slightly larger turbo. It spools fast, makes 23 psi, but I have the fuel turned down to keep egts down, I think a bigger turbo would help. That being said, it easily takes my 4x4 ranger to 70 and returns 28-30 mpg in a truck that sits tall and has mud terrains.
As for why I'm selling, I want to have a 12 second 1/4 mile truck powered by a Kubota. Absolutely nothing wrong with this one
Old Aug 9, 2014 | 11:33 PM
RedChevy44's Avatar
How much are you asking for that setup?
Old Aug 10, 2014 | 04:21 AM
wyoranch's Avatar
Sorry. I'll take $2500 for it all
Old Aug 10, 2014 | 09:22 AM
wyoranch's Avatar
Well, i found the motor i want to put in it, ill take $2000 for it all. Thats quite a bit less than it would cost you to do yourself and all the work is done.
Old Aug 11, 2014 | 04:24 AM
wyoranch's Avatar
Sold it. Thanks for the interest guys
THW
Mar 17, 2015 08:31 PM
miked2805
Oct 19, 2014 11:02 PM
