1993 cummins speedometer and charging system and overdrive not working
Old Aug 7, 2014 | 11:35 PM
lakota's Avatar
Default 1993 cummins speedometer and charging system and overdrive not working
I wrecked the truck on the passenger side front and back the electronics quit working now I'm trying to bring it back from the dead I was told a crankshaft positioning sensor but mine is fine dose anyone else know what it could be
Old Aug 29, 2014 | 11:29 AM
1993firstgennewbie's Avatar
It can only be the crank position sensor, but I guess it could be a wiring gremlin, how did you determine your VSS is good (its actually called vehicle speed sensor)
Old Sep 12, 2014 | 09:12 AM
lakota's Avatar
I replaced it with a new one from koi I got the charging to work its just overdrive and the speedometer now
Old Sep 18, 2014 | 02:21 PM
u2slow's Avatar
On my ramcharger I bungled up reinstalling the speedo on the tcase after changing the output seal. I ended up with the same problem.
