Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
???Fuel Pressure Regulator???
Old Jul 30, 2014 | 07:12 PM
SmokinTide's Avatar
Default ???Fuel Pressure Regulator???
I've acquired a skip or surge. Under throttle the truck runs good. Does not over heat. No coolant in the crankcase. No fuel in the crankcase. No smoke other than black out the pipe. Runs and idles fine while reaching operating temperature. Once it gets to approximately 190/200 degrees it starts a random surge in neutral or in gear. Seems to be worse in gear. The fuel filter (wix) has 100 miles on it. I'm currently running a mixture of hotshot extreme FUEL additive to see if it might be a clogged injector. Mixture is proportioned for 12 gallons to see if that would clear it up. Does anyone have an opinion or experienced these symptoms. I haven't checked fuel rail pressure. These symptoms are present weather tuned or not. Running a super chips have tried ALL settings and now running stock. I have already replaced the #2 &7 pigtails previously. I'm thinking fuel pressure regulator?
Old Jul 31, 2014 | 05:53 PM
SmokinTide's Avatar
Really 105 views no comments
Old Sep 15, 2014 | 06:15 PM
Dmaxjim's Avatar
I had around the same issue. It would surge at stop lights like ever 3-4 secs. I also it slowly got worse over time. Put a new fuel pressure regulator in it and it seemed to stop the surging.
Old Sep 20, 2014 | 02:16 PM
detroitdiesel idi's Avatar
Install a lbz regulator on
Old Sep 24, 2014 | 05:54 PM
2500HeavyDuty's Avatar
check your engine wire harness coming off your ficm, esp around the alternator bracket and by the valve cover for any wires rubbing. makre sure to resecure them and keep them from rubbing.
Old Oct 16, 2014 | 02:21 AM
SmokinTide's Avatar
Replaced the FPR and rebuilt fuel filter head. And removed some.... parts. Think the problems solved.
Old Jun 19, 2015 | 06:19 PM
Workingman's Avatar
What parts did you remove? I have the same issues. I replaced the FPR, new fuel filter, checked wiring harness from the FICM and the issue seems to be getting progressively worse under power. The surging went away at idle but going down the road at about 60 it will buck and surge.
Old Jun 20, 2015 | 12:09 PM
gillespie3033's Avatar
when my lly surges while stopped i add Kleen fuel additive an it will correct the problem . i was informed it was moisture in the fuel rail
Old Jul 15, 2015 | 06:11 PM
SmokinTide's Avatar
Workingman
Could be filterhead or 2&7 injector wires. The injector wires will more than likely throw a code and limp out.
May be a fuel pump?
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
19Samahi72
Chevy/GMC Duramax 01-04 LB7
Jan 26, 2015 10:55 AM
veggyoilkid
Nov 10, 2014 12:39 PM
Jeremy Babb
13
Oct 1, 2014 06:27 AM
