04 LB7 Using oil
Old Jul 24, 2014 | 11:08 AM
CharlestonFF's Avatar
Default 04 LB7 Using oil
I checked the oil the other day something I probably should do more often since I found that I was short 3 quarts of oil. The truck has 190,000 mi. My truck doesn't smoke, there isn't any blow by, but I need to check the intercooler line. There are also no drips that I have found and especially no oil on the ground. I have no Idea where the oil is going! Does anybody have any Ideas. I called my mechanic and he thinks an injector is filling up the oil pan but I don't think its possible because I replaced the injectors when I got the truck 3 yrs ago! Anybody know how much it would cost to fix the problem if there is oil in the intercooler line? Thanks for any advice guys!
Old Jul 25, 2014 | 01:59 AM
4x4manonbroke's Avatar
ok, if it was using oil then an injector would not be even close to the issue ... #1
#2 check your turbo out .. check for slop and for/aft loosness..... if nothing there , inspect underside closley for leaks/seeps......
How long has it been and is the 3 qts a regular problem ? what oil are you running ?
Old Aug 5, 2014 | 11:43 AM
Outlaw88's Avatar
check your coolant. is it milky looking? Its possible that it could be a bad oil cooler and its just going in the radiator.
Old Aug 5, 2014 | 02:39 PM
Good point ....
Old Nov 3, 2014 | 03:02 PM
Well a little update on the truck..... I am using a quart about 4,000 mi... I pull a landscape trailer and drive this truck everyday. I hit about 194,000 and either the injector got stuck open or I have a mechanical failure in the #4 piston. Shop did a diagnostic test and the rate on the 4 cylinder was around 10-12 I believe. Once the 4 cylinder was shot off the chopping stopped. Still haven't found an oil leak. The coolant is not milky, there are no visible oil leaks. Now I am waiting on the truck to get into the shop to tear it apart.
Old Nov 3, 2014 | 10:26 PM
thats not enough oil to be concerned with .. most likley its because your working the engine good and hard .... A good running engine will consume a bit of oil .. 1 Qt @ 4K is more than ok ...
Old Nov 4, 2014 | 09:26 AM
Outlaw88's Avatar
I would NOT say that is a safe amount. Especially for a duramax, it's unusual.
Old Nov 4, 2014 | 09:03 PM
2004LB7's Avatar
I agree. The duramax does not normally consume much oil if any at all. My lb7 needs no extra oil between oil changes and i dont baby it.
It could be possible that the stuck injector washed the cylinder wall and now the wall/rings are scratched and burning oil.
You could try water injection for a few thousand miles to clean up the cylinders and see it stops using oil. A cheap setup could be rigged pre-turbo with the windsheld washer pump that you could use just for this.
Old Nov 5, 2014 | 11:51 AM
Outlaw88's Avatar
Old Nov 6, 2014 | 12:31 AM
My LB7 uses a bit of oil .. never smokes runs awesome .. ? maybe we have the same issues ???
