Head gaskits on a 85 ford 6.9 idi
Old Jun 25, 2014 | 07:55 PM
85IDI_International's Avatar
Default Head gaskits on a 85 ford 6.9 idi
my truck dumps white smoke, leaking oil, oil in my exhaust, and when i remove the cap of my fuel injection pump the liquid under it is milky. Do i have a cracked head or a blown head gaskit??? and what should i do for either problem?
Old Jun 25, 2014 | 08:24 PM
RanchhandTCR's Avatar
Im not familiar with the 6.9L IDI, but white smoke is also unburned fuel also, or a sign of leaking antifreeze I would see if you exhaust smells sweet or if it smelled like raw diesel. Now if you have oil coming out of the exhaust it could mean you have a worn cylinder, cracked head, bad valve. ECT, ECT. Best place to start is to perform a cylinder compression test, see which side has low compression and tackle that side. If its a blown head gasket simply remove head, clean block and head, and inspect the head and move on with life. If you have a cracked head then well.. You need a new head, and head gasket. But if you have low compression in a cylinder, when you do the compression test see if you can see oil or any containments or damage in the cylinder. Hope that I was some of assistance.
Old Jun 27, 2014 | 08:13 PM
Thank you so much. i will get right on that and i will let you know which problem it is.
Old Jun 27, 2014 | 09:48 PM
4x4manonbroke's Avatar
LOL>.. You make this sound easy ... I did that in my truck and guess what ... now I have the engine out ...
its a 6.9 and it most likley just hasnt been driven enough to remove the moisture from the oil, short trips and such will do that ...
Old Jun 28, 2014 | 01:02 AM
I try just the lack of wanting to write a manual..
Old Jun 28, 2014 | 10:51 AM
LOL... hey if you know something never be afraid to write it out... I have lots of knowledge, some good, and some just more oppinion based ..
that being said , Please, if you ever have input , lets hear it ..
Old Jun 28, 2014 | 02:51 PM
I try, most of my experience is with B series cummins and Heavy Trucks..
Old Jun 28, 2014 | 04:24 PM
I hear ya, i build 6V-S60's .. occasionally a Kitty..
Old Jun 28, 2014 | 04:56 PM
Ya work on them all they way through from Bumper to Bumper. Most of my builds have been B series and DT466e. No kitty cat yet.
Old Jun 28, 2014 | 07:51 PM
i have herd many gret things about the dt engine line ... and of course the B is ALWAYS da bomb .. and simple too ..
