1996 F250 7.3
Old Jun 16, 2014 | 01:32 PM
Rees Guide's Avatar
Default 1996 F250 7.3
Hi guys, new hear but will be around. Love my ole Powerstroke and need a place to check in with from time to time. have owned these model trucks since they came out so maybe I can help others out as well.
Yesterday my ole stroke started missing BAD when I tried to crank it. Got it home and started to fool with it this morning. I unplug the glow plug/injector harness on the front of the valve cover and no change in the missing so I unplug the other one on that side, still no change. Go around and unplug the front one and it dies. Plug it back up and crank the truck back up, unplug the back one and it dies again. So I figure the valve cover gasket so I change it, no change in it. Seems to be missing on the whole drivers side.
Any suggestions?????
Old Jun 16, 2014 | 07:13 PM
joebob3093's Avatar
Moderator
Did you just change valve cover gaskets or the harnesses inside too?
Old Jun 16, 2014 | 07:30 PM
Rees Guide's Avatar
Replaced the gasket but no help. Checked the injector harnesses under the cover and they were good. Also checked the outside harness back to the IDM, my thinking is the IDM is shot.
Old Jun 16, 2014 | 09:23 PM
joebob3093's Avatar
Moderator
Know anyone with an IDM you could try?
Old Jun 16, 2014 | 09:25 PM
Rees Guide's Avatar
Been racking my brain trying to think of where one was that was junked, may can borrow a friends off his truck just to be sure that's it. Good idea, thanks. Will post back what I find.
Old Jun 18, 2014 | 06:12 PM
Rees Guide's Avatar
Got a IDM and she fired up. Has always run rough when first cranking and it is still doing the same. Is there a way to check to be sure each injector is working. Thanks
Old Jun 18, 2014 | 06:21 PM
joebob3093's Avatar
Moderator
You can do a buzz and contribution test if you have a scanner
Old Jun 18, 2014 | 06:33 PM
Rees Guide's Avatar
don't have a scanner so without taking it somewhere that wont work. Still have the valve cover off on drivers side as that is where the problem was. Cranked the front 3 all are squirting oil as they should but the back one is not.
Old Jun 18, 2014 | 06:38 PM
joebob3093's Avatar
Moderator
Can try to unplug each injector individually and listen for a change in idle
Old Jun 18, 2014 | 06:48 PM
Rees Guide's Avatar
Did that and it aint hitting a lick. How hard they to change??
